[Release Note] Nebula Switch 100 Series - Phase 6 firmware has been released!
Nebula Moderator
Zyxel Nebula Switch 100 Series
Release Note
December, 2018
Firmware Version on all models
Zyxel NSW100-10 - V3.00(ABHW.0)C0
Zyxel NSW100-10P - V3.00(ABGO.0)C0
Zyxel NSW100-28 - V3.00(ABHX.0)C0
Zyxel NSW100-28P - V3.00(ABBT.0)C0
New Feature and Enhancements
- Add Port isolation feature.
- Add IGMP-Filtering, Querier, Leave mode feature.
- Add IPTV report.
- Switch Port detail page is enhanced to display
IGMP counters.
- LLDP enhancement for PoE.
- Add speed/duplex in syslog while port link up.
- Encrypt administrator password on the local device.
- Fixed link up speed is 1G, but NCC shows 9589M.
- Fixed
LLDP information from some other brand devices may cause the connectivity to
NCC is unstable.
Nebula Forum Moderator
The new firmware is available now!
Proceed to upgrade your device now to enjoy the new features as listed above or wait until scheduled upgrade takes place.
Nebula Forum Moderator0 -
Did this add the variable speed fan control as well or was fan speed slightly reduced? I just performed the update. It seems the switch dropped 1 or 2 db but I see nothing in the UI to indicate this. Currently I am only using 2 POE ports, drawing under 10w total and it runs cool even with the lower fan speed.0
Hi @GadgetryTech
The release includes the smart fan design as the variable speed fan control you mentioned. The system will start up at the lowest fan speed, and during operation, fan speed will be adjusted linearly based on system temperature.
So basically this is determined by the device itself.
BTW, the NebulaFlex switches are less noisy by hardware nature since the maximum fan speed has lower rpm.
Cheers1 -
Thank you. I heard the fan drop a little in speed when it rebooted after the update. At least I know I'm not crazy. Are the plans to for more insight on hardware such as sensor thermals and fan speed (rpm). The switch is currently drawing less than 10w so I wonder if the fan speed could be dialed back even more. Thanks!0
Hi @GadgetryTech,
Thanks for your advice, I will post a new topic in Idea section for "Current temperature and Fan speed of Switch can be shown on Nebula CC".
Please note that the smart fan feature only supports on NSW200 series and Hybrid Switch due to hardware limitation. Also the fan speed depends on the temperature of Switch, not how many PoE power Switch send.
Hope it helps.
Jason0
- 7K All Categories
- 1.4K Nebula
- 29 Nebula Ideas
- 35 Nebula Status and Incidents
- 3.9K Security
- 200 Security Ideas
- 719 Switch
- 29 Switch Ideas
- 593 WirelessLAN
- 8 WLAN Ideas
- 4.5K Consumer Product
- 97 Service & License
- 215 New and Release
- 38 Security Advisories
- 496 FAQ
- 217 Nebula FAQ
- 120 Security FAQ
- 72 Switch FAQ
- 67 WirelessLAN FAQ
- 4 Consumer Product FAQ
- Documents
- 30 Nebula Monthly Express
- 43 About Community
- 31 Security Highlight
