High CPU load for switches GS1900-24E
2»
  • AFT
    AFT Posts: 3  Freshman Member
    Hi Zyxel_Lucious
    Thanks for the input, pretty interesting suggestion. I'm going to try this right now.
    Thank you very much!
    BR,
    Marco
  • AFT
    edited July 2019
    @Zyxel_Lucious Fantastic, this did the trick with 100% CPU load! Thanks a lot and have a great day!👍️
  • Tiron
    Tiron Posts: 5  Freshman Member
    I am having the the same 100% CPU issue with GS1900-8HP here.
    Latest firmware V2.40(AAHI.2) | 06/05/2019, but solution from @Zyxel_Lucious is not working.
    After reboot the CPU is fine, haven't tested after which time it goes up.
    Any other hints for a solution? No loops detected.
  • Yuri_S
    Yuri_S Posts: 9  Freshman Member
    Kindly check any security devices and solutions - antiviruses, network scanners, etc.
    In my situation problem was when LANSweeper started network scan. It always raised CPU load.
    Regards
  • Tiron
    I'm newbie to network details. But is it possible that a rsync backup-job not finding the target could cause this mess? Deactivated the job on NAS and so far ... keep fingers crossed
  • Tiron
    And what about memory usage at 70% without real traffic (only my mac when writing this)?
    Only service that comes to my mind is the SAT>IP Server running.
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 282  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @Tiron
    Welcome to Zyxel community.
    As @Yuri_S mentioned, some security related application/scanner may cause the issue.
    Try using "Remote Access Control" (Configuration -> Management -> Remote Access Control) restricting a desired access IP range. It prevents untrusted packet from CPU processing.
    As for memory, because of certain background process running in normal operating, the memory usage 70% can be considered no problem on GS1900 series.
    Zyxel_Lucious
  • Tiron
    Would this be the correct setting to only allow one IP for remote access? All other will be ignored?
  • Ace
    Ace Posts: 25  Freshman Member
    First Answer First Comment Friend Collector Sixth Anniversary
    @Tiron
    No, your source ip mask is 255.255.255.0, its allow 192.168.5.0/24 to access switch.
    If you want to allow only for 192.168.5.20  to remote access, source ip mask should be "255.255.255.255".
  • Tiron
    Right! What a stupid mistake :s
