[NEBULA] Client Reporting
Hello @David_Charron
We actually can send the report in Gateway>NSS analysis, it can list the top application usage and blocked page where user surf.
/ChrisChris
I would need it for a specific user using the Wi-Fi. There is a possibility of this person surfing a "Bad Site".
Thanks for assistance on this.
Greeting @David_Charron ,
We can check the block site by Content Filtering and refer to which client has surfing it, in current design it only has IP record, in the next NCC release (10/28) will add the description column as like in client page which can help to recognize the user.
If you want to monitor all sites even the passing one then I'm sorry it's not doable in current stage, I can move this thread to the Ideas section after the discussion.?
/Chris
Chris
Hey @David_Charron
Thanks for your input. Just wanted to add some good news, on next Monday you will be able to find the Applications, blocked Content Filtering and Antivirus hits per client in the Gateway Client page, as part of the new Nebula 2.0 (beta).
This has been widely requested by many user and as always, we heard you guys. Hope this fits your need ?
Cheers
Bayardo
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
