GS1910-24 and GS1920-24 losing configuration
To fill in some details: The switch is a GS1920-24HP with Boot Version V1.00 | 03/21/2014 and Firmware Version V4.50(AAOC.2) | 02/27/2018. I think I have now tried everything I can think of to try and save the configuration. It makes no difference if I use config 1 or config 2. I have factory reset the device several times. Even just performing a reboot from the management console (using either config 1 or config 2 to boot to) makes the router lose the configuration completely.
And yes, the funny thing is, I have that old GS1910-24HP next to this router and it has exactly the same fault. I could of course source another used GS1920 for a decent price but I feel hesitant to ever touch anything from this product family again... Do you have any ideas?
When you press the Save button does the page show that the configuration has been saved?
I got this sorted out, finally! For reasons beyond my understanding, the switch only keeps configuration for "Config 1". If set to boot "Config 2", it always boots with factory default settings, despite having saved a modified "Config 2" (via the "Maintenance" page). I originally only upgraded "Config 2" to most recent ROM version, as my idea was to leave "Config 1" intact, using an older version. This was obviously not a good idea. I changed the router to boot "Config 1" instead and then reflashed it to most recent ROM. Both configs are now in the same version and "Config 1" is keeping the saved settings. All sorted out. Now it is time to start tinkering with the VLAN configs...
Hi @Jouko
There is a configuration checking mechanism when the version gap between firmware image 1,2 is too big (For example: image 1 is 4.10 and image 2 is 4.50) and could lead to default setting to avoid mismatched configuration.
So it's better to keep both firmware as close or same trunk version to prevent the problem.
Anyway, glad that you sorted it all out.
Zyxel_Lucious
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
