Trunks, VLAN, and uplinks.
Aaron_W
Aaron_W Posts: 5  Freshman Member
edited August 2022 in Switch
Hello. I'm coming from an HP/Cisco background but I'm running into issues getting this GS1900-10HP switch connected to my network.
For this switch I'm concerned with three VLAN.
VLAN 1 - Default VLAN, the switch has an IP on this VLAN.
VLAN 60 - VOIP VLAN.
VLAN 150 - DATA VLAN.
The switch works fine connected to my HP switch via port 1, I can ping it and log into the menu. Under VLAN Port I have it untagged on VL1, and tagged on VL 60-150. Very HP'ish.
Now on port 2 I want to have a PC and a VOIP Phone. Normally on HP I'd have it untagged on VL150 and tagged on VL60 so I set it the same. I have it connected like this, Switch>phone>PC.
The phone works. But I cannot connect to the PC.
So to sum it up VLAN are as follows.
VL1 - Untagged 1, 2-8 excluded
VL 60 - Tagged 1-8
VL 150 - Tagged 1, Untagged 2-8
Port 1 is set as a VLAN Trunk as well. Do I need to set a PVID on each port?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 282  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited November 2019
    Hi @Aaron_W
    Based on your description, you should also
    1) Set PVID 150 on port 2 for ingress untagged packets from the PC.
    2) Set the VoIP phone tagged-out VLAN 60.
    Zyxel_Lucious
  • Aaron_W
    Fixed it. Had a tag wrong on int 1. Thanks for the help.
  • Aaron_W
    Spoke too soon. Got the PC connected on port 2. But now the phone isn't working.
    The Voice VLAN is set for VLAN 60.
    Its tagged on all ports on the switch. But my phone on port 2 cannot be reached now.
    The Phone is connected to port 2, then the PC connects via the IP Phones PC port. So now my situation is reversed.
    Port 1 is my trunk port, untagged VL1, tagged VL 60 & 150.
    Port 2 is untagged VL 150, tagged VL 60.
    The phone now cannot reach its SIP proxy on the same VLAN and I cannot ping it.
    Here is the setting via the CLI
  • Aaron_W
    I reset the switch and reconfigured it. I notice that it is now keeping VL60 as its Voice VLAN. PC works, phone still isn't working. These are on port 2.
    Here is the config.
    GS1900# sh run
    ! System Description: ZyXEL GS1900-10HP Switch
    ! Revision: A1
    ! Serial Number: S172L07003012
    ! MAC Address Range: B8:EC:A3:26:D0:53 - B8:EC:A3:26:D0:5D
    ! Boot Version: V2.00 | 07/17/2015
    ! Firmware Version: V2.40(AAZI.2) | 06/05/2019
    ! System Up Time: 0 days, 0 hours, 32 mins, 57 secs
    ip address 172.16.1.38 mask 255.255.255.0
    ip default-gateway 172.16.1.81
    ip dns 172.16.2.1
    username "admin" secret encrypted 1N4D/wJ51UFHVOFLzBJQhg==
    username "aaron" secret encrypted SUuSVC18V6KHNc8Unu6/oQ==
    vlan 60
     name "VOIP0060"
    vlan 150
     name "SHOP0150"
    voice-vlan vlan 60
    voice-vlan
    voice-vlan oui-table 00:E0:BB "3COM"
    voice-vlan oui-table 00:03:6B "Cisco"
    voice-vlan oui-table 00:E0:75 "Veritel"
    voice-vlan oui-table 00:D0:1E "Pingtel"
    voice-vlan oui-table 00:01:E3 "Siemens"
    voice-vlan oui-table 00:60:B9 "NEC/Philips"
    voice-vlan oui-table 00:0F:E2 "H3C"
    voice-vlan oui-table 00:09:6E "Avaya"
    voice-vlan oui-table 00:0F:D3 "Digium"
    spanning-tree mst configuration
     name "B8:EC:A3:26:D0:53"
    no snmp community "public"
    snmp community "Nonpublic" ro
    management access-list default
    interface lag1
     switchport hybrid allowed vlan add 60 tagged
     switchport hybrid allowed vlan remove 1
    interface lag2
    interface lag3
    interface lag4
    interface lag5
    interface lag6
    interface lag7
    interface lag8
    interface 1
     switchport hybrid vlan-trunking
     switchport hybrid allowed vlan add 60,150 tagged
    interface 2
     switchport hybrid pvid 150
     switchport hybrid allowed vlan add 150 untagged
     voice-vlan
    interface 3
     voice-vlan
    interface 4
     voice-vlan
    interface 5
     voice-vlan
    interface 6
     voice-vlan
    interface 7
     voice-vlan
    interface 8
     voice-vlan
    interface 9
     voice-vlan
    interface 10
     voice-vlan
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126  Zyxel Employee
    Hi @Aaron_W
    Please try to configure IP phone's VLAN to VLAN 60 and test if the issue still exist.
    Thanks for your help
    Zyxel_Derrick
  • Aaron_W
    The IP Phone is on VL60 in its network settings. The switch can ping the phone server but the switch cannot pass traffic from the phone on tagged VL60.
