Does Switch models XGS4600-32F and GS2210-24HP support IGMP query solicitation?
Thank you for the information and attention.
Best regards,
Caio.
Lucious,
If you allow me, I have one more question regarding this matter. Does these Switches have any feature that can replace the IGMP query solicitation?
Thanks in advance.
Caio.
Hi @Caio
We do have a workaround for you, please refer to the example of ring topology as below
- Enable STP and IGMP snooping on every switch, and make sure that switch 1 as the root bridge and IGMP Querier.
- Set Unknown Multicast Frame as "Drop" on every switch.
- Change the IGMP Quierier Mode to "Fixed" for every port between switches.
The fixed mode can ensure the demanding stream won't be interrupted in case of a topology change.
Zyxel_Lucious
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
