local domain to website domain forwarder
2»
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    Hello phzyxel,
    Add below rule on the Domain zone forwarder and try again.
    Set the * on the Domain Zone, 4.2.2.2 on the DNS server.
    Please check the picture.
    Charlie
  • phzyxel
    phzyxel Posts: 8 image  Freshman Member
    Hi Zyxel_Charlie,
    upon trying the error below occurred.
  • Zyxel_Charlie
    Hello phzyxel,
    You should add the domain name and DNS server to be 4.2.2.2 on the Domain Zone Forwarder.
    Here is an example:
     Also, according to your latest update, it appears 500 Internal server error. it means something has gone wrong with the website or it’s a problem with the site you’re trying to visit. Please check the configuration on Server side and the configuration of  web browser.
    Charlie
  • CHS
    CHS Posts: 181 image  Master Member
    HTTP 500 error....?
    I don't think the reason is coming from DNS issue.
    Does server is working fine if client accessing to server by LAN IP?
