SSL VPN traffic prioritization
Martin_Kuchar
Hello, please are SSL VPN packets prioritized as standard on USG110, or we need to setup BWM and manualy add SSL VPN port for guarantee not dropping SSL VPN tunnel by other users with for example high www traffic ?
@Martin_Kuchar
If you want the traffic of SSL VPN tunnel prioritized, you can refer to the below configuration.
EX: ISP provide 10 Mbps, Go to BWM and create the two profiles
Charlie1 -
Hello, here is shown Bandwidth Shaping with 8Mbps for SSL and 2Mbps for the rest. I have some questions..1) What is the interface Object "SSL" and how is created?2) Here in this example, the 8Mbps are locked for SSL, or the SSL have just priority when used? In other words, if no SSL is used (no VPN connected), is all 10Mbps available for "normal" users? And3) if somebody is connected with VPN, is still the full 10Mbps available for "normal" users, if the VPN connected users do not need bandwidth?Thank you for clarification,Martin0
Pls answer at least my questions 2 and 3, thanks
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
