[NEBULA] GS1920-8HP connected to Nebula - Unable to access local login
Quality_Drive_Away
Quality_Drive_Away Posts: 14
edited April 2021 in Nebula
Is it normal not to be able to login to the local IP interface of a GS1920-8HP switch that is connected to Nebula?
Best Answers
  • Quality_Drive_Away
    Found it! Thank You!
  • I joined my NWA1123 wifi access point to nebula and now I can't log in locally. Tried with both my original username & password as well as the username & password I use on the nebula website.
    I don't see General Settings in the Nebula Control Settings.
  • Zyxel_Jason
    Zyxel_Jason Posts: 387
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Sales Associate 25 Answers First Comment
    Hi @flaccidupsilon ,
    Welcome Zyxel community!
    If your AP is online on NCC, you should be able to find your username and password in General setting page, location is at SITE-WIDE>Configure>General setting, then you can find the setting like below.
    Hope it helps.
    Click this link to start: https://bit.ly/3R2Wx52
    Jason
  • Thanks, that does help. I'm in now.
    Two points: I didn't realize that my local password would be changed by connecting to Nebula. Second, you're the first to mention "SITE-WIDE", which was the key to finding General Settings.
    Thanks again Jason!
Nebula Tips & Tricks
