NWA5121-N Device can't connect to cloud server post Firmware Update ZLD4.35
@iSpeed,On our USG40 with firmware 4.35(AALA.0), the AP firmware for NWA5121-NI/NWA5123-NI/NWA5121-N are successfully downloaded from the server.Since we don’t have the same symptom on USG40, I will contact you in private message for more information.
I've the same issue with a ATP200. Can I get the information as well to fix this problem.
Thx
Rene, It's an anomaly if you hit refresh you will see it actually does the update.
hi actually it's not an anomaly. I've changed the capwap/ftp settings as well nothing happend..
Refer to that post: https://businessforum.zyxel.com/discussion/3662/ap-firmware-unable-to-reset-the-download-path-to-official#latest
Maybe it helps, especially my last reply.
- 588 USG FLEX H Series
- 477 News and Release
