XS3700 SNMP Config問題
KBWang
KBWang 文章數: 1
First Anniversary
已編輯 二月 2021 乙太網路交換器
請問我在XS3700的設定檔中有以下四行關於SNMP的設定不太清楚其用意,請問可以說明一下嗎?謝謝
classifier "snmp securityip" destination-socket 161 ipv6-source-ip 2001:288:0000::1 prefix-length 128 ipv6-next-header udp
classifier "snmp securityip24" destination-socket 161 ipv6-source-ip 2001:288:0000::1 prefix-length 128 ipv6-next-header udp
policy snmpsecurityip classifier "snmp securityip" egress-port 1 priority 0 dscp 0 tos 0 bndwidth 0 out-of-profile-dscp 0 forward-action forward outgoing-eport out-of-profile-action forward
policy snmpsecurityip24 classifier "snmp securityip24" egress-port 24 priority 0 dscp 0 tos 0 bandwidth 0 out-of-profile-dscp 0 forward-action forward outgoing-eport out-of-profile-action forward
另外,還有這兩行DHCP RELAY的設定
dhcp relay 1 helper-address 163.19.149.38
dhcp relay 1 source-address 120.104.77.254
  • Zyxel_Derrick
    Zyxel_Derrick 文章數: 126  Zyxel Employee
    First Anniversary Friend Collector First Answer First Comment
    已編輯 一月 2020
    Hi KBWang
    關於您提到的設定是屬於ACL的設定
    一個classifier搭配一個policy rule等於一個ACL
    以您的設定為例,從classifier name "snmp securityip"得知
    是與
    policy snmpsecurityip classifier "snmp securityip" egress-port 1 priority 0 dscp 0 tos 0 bandwidth 0 out-of-profile-dscp 0 forward-action forward outgoing-eport out-of-profile-action forward
    搭配,只要進來的封包有踩中 classifier 的設定也就是有符合您設定的"destination-socket 161 ipv6-source-ip 2001:288:0000::1 prefix-length 128 ipv6-next-header udp" 就會去看設定的 policy 為何,也就是 egress-port 1 priority 0 dscp 0 tos 0 bandwidth 0 out-of-profile-dscp 0 forward-action forward outgoing-eport out-of-profile-action forward,而採取下一步動作,以此類推。
    關於 dhcp relay 1 helper-address 163.19.149.38 是指當client與server在不同domain時,將DHCP封包relay到此IP Server
    關於 dhcp relay 1 source-address 120.104.77.254 是指若有多個IP interface時,由此IP發DHCP封包去要IP
    Best regards
    Zyxel_Derrick
  • Zyxel_Derrick
    已編輯 一月 2020
    補充說明一下
    以上述提到的第一組config為例
    若進來的封包有符合destination socket 161,source ip 為 IPv6 2001:288:0000::1 prefix-length 128區間且ipv6-next-header udp,此封包就會被執行policy "Send the packet to the egress port" ,根據您的設定封包會被送到port 1
    以第二組config為例
    若進來的封包有符合destination socket 161,source ip 為 IPv6 2001:288:0000::1 prefix-length 128區間且ipv6-next-header udp,此封包就會被執行policy "Send the packet to the egress port" ,根據您的設定封包會被送到port 24
    由於兩組classifier條件相同,只會執行名字比較長的那筆,也就是第二組config會被執行,因此,有符合條件的封包會被送到 port 24
    Best regards,
    Zyxel_Derrick
