[NEBULA] Port Group 1 & 2 - how to allow device
dpat
dpat Posts: 5 image  Freshman Member
edited April 2021 in Nebula
I want to allow some device on port group 1 (LAN1) to be see by devices on port group 2 (LAN2).
How can I do ?
Thank you
  • dpat
    Every things are ok now.
    My server 172.16.1.10 had a bad gateway. 172.16.1.0 instead of 172.16.1.1
    It's my fault. Sorry.
    Thank you very much.
    Denis
  • ivers
    ivers Posts: 45 image  Freshman Member
    First Comment First Answer Friend Collector Fifth Anniversary
    @dpat
    NSG didn't block any traffic between LANs in default setting, what's the issue you encounter?
  • dpat
    Thank you.
    I have a device (172.16.1.10) on LAN1 (port group1) 172.16.1.1/24
    Devices on the LAN2 (port group2) 172.16.2.1/24 can ping 172.16.1.1 but not 172.16.1.10 and LAN2 isn't a guest LAN
    The VPN Remote Access 172.16.9.1/24 can ping the device on 172.16.1.10
    I don't understand why LAN2 can't ping 172.16.1.10.
    All FireWall rules are disabled, there is no policy route, network access method on LAN1 and LAN2 are disabled.
    Thanks for your help.
    Denis
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hello @dpat
    Welcome to the community!
    I would like to check your organization setting, please check your Inbox message for more detail information.?
    /Chris
  • dpat
    Denis
Nebula Tips & Tricks
