[NEBULA] External Captive Portal authentication
2»
  • Zyxel_Freda
    Zyxel_Freda Posts: 397
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @SB10,
    Thanks for your clarify and sharing the information. We'll check it and fix this issue asap.
  • Iwannaquitthegym
    Iwannaquitthegym Posts: 23
    Awesome finding @SB10! My SSIDs do not contain symbols that's why I didn't experienced the same. Thanks for the warning! Hopefully this can be fixed tho.
  • SB10
    SB10 Posts: 8
    edited February 2020
    Thanks @Nebula_Freda
    Btw, is there any update or maintenance going on right now?
    I am only getting "apmac" in the URL at the moment
    Edit: looks like it works now, i don't know why that happened
  • Zyxel_Freda
    Hi @SB10 ,
    After we checked, there's no abnormal on NCC server at the time you posted, so would you screenshot for us if the NCC displays incorrect.
    For the SSID with '#' symbol issue, we have a date firmware for fixing it, and please let me know if you need it.
    Thanks.
  • SB10
    SB10 Posts: 8
    The '#' character is something i can survive without, i will just not use it in the SSID, but it would be nice to fix that for future users.
Nebula Tips & Tricks
