USG 110 - wan priority
Sandro44
Sandro44 Posts: 1
edited April 2021 in Security
Hi there ! Im using Zyxel USG 110. I would know how can I prioritize a wan link , for example put the wan 2 in priority 1, not the wan 1. Because I have 2 internet links (WAN1 with a VPN & with ppp interface) and wan2 which is with my highest bandwidth. But my LAN goes out to the lowest bandwidth link!!
I tried to modify the wan zone , but I cant remove wan2 links. I wanted to add another rule with Lan outgoing to my wan2 link with a new zone with my wan2 exclusively. But it doesnt work.
An easy way to do that ?
Also, if I add this routing rule, the LAN outgoing will go threw wan2 link or Im wrong ?
Thanks for your help
Security Highlight
