[NEBULA] Routing on NSG100 when using Server-and-Client VPN
Hi
How can I set up a route from a PC that is connected to an NSG100 that is set up as Client in a Server-and-Client VPN setup to a network connected to nsg100 that is Server in this VPN connection?
Routing from client 10.50.50.10 to server 10.100.100.10
See attachments
When I can't use policy based routing when we use Server-Client VPN...
Hi @Elgen007
Since server-client scenario cannot support policy route, it's a design limitation, is that possible for you to change the VPN scenario?
Hi
I tried and changed the VPN setup to Hub-and-Spoke but then I got into trouble with several of the VPN connections not coming up again, but I got routed traffic. When I changed back to Server-Client, all VPN came up again, but I couldn't route traffic. I hope there are opportunities to set up routes with Server-Client VPN if not via the web but via command line.
h
Olav
Hi Olav,
I can help you to check on this to find if other scenario can fit in this case, will PM you please check your Inbox message.☺️
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
