[NEBULA] Routing on NSG100 when using Server-and-Client VPN
Hi
How can I set up a route from a PC that is connected to an NSG100 that is set up as Client in a Server-and-Client VPN setup to a network connected to nsg100 that is Server in this VPN connection?
Routing from client 10.50.50.10 to server 10.100.100.10
See attachments
When I can't use policy based routing when we use Server-Client VPN...
Hi @Elgen007
Since server-client scenario cannot support policy route, it's a design limitation, is that possible for you to change the VPN scenario?
Chris
Hi
I tried and changed the VPN setup to Hub-and-Spoke but then I got into trouble with several of the VPN connections not coming up again, but I got routed traffic. When I changed back to Server-Client, all VPN came up again, but I couldn't route traffic. I hope there are opportunities to set up routes with Server-Client VPN if not via the web but via command line.
h
Olav
Hi Olav,
I can help you to check on this to find if other scenario can fit in this case, will PM you please check your Inbox message.☺️
Chris
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
