Replace self-signed certificate on GS1920-24HPv2
alehzn
alehzn Posts: 36
edited April 2021 in Nebula
How to replace the self-signed certificate on the GS1920-24HPv2 switch? Seems to not be possible over GUI nor over SSH?!
Firmware: V4.60(ABMI.0) | 01/20/2020
Thank you in advance.
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 289
    5 Answers First Comment Friend Collector Fourth Anniversary
    Hi @alehzn,
    For the current designed, NCC doesn't support self-signed certificate feature.
    We already understand your request and will move your post to the ideas section so others that have the same need can support this request ?.
    Thanks.
    Jonas,
  • alehzn
    alehzn Posts: 36
    Hello @Nebula_Jonas
    Thanks for your reply. Do you have a roadmap for this feature? The support for exchanging self-signed certificate is crucial. If it won't be supported in the near future, I have toreturn the switch and look for alternatives.
    Thanks for your understanding.
  • alehzn
    alehzn Posts: 36
    edited March 2020
    Other question: Do other ZyXEL switches support it?
  • Zyxel_Jonas
    Hi @alehzn
    Yes, we do support self-signed certificate on other Zyxel switch models, as follows:
    (for standalone mode only)
    XGS4600 and XS3800 on firmware v4.60.
    GS1920 and GS1350 (future release around Q3)
    I would like to clarify that you would like this feature on Cloud mode? If yes, is it convenient to share your application? Because on cloud mode, all configuration could be done on NCC, it's not necessary accessing to WEB GUI.
    -Jonas
    Jonas,
  • alehzn
    alehzn Posts: 36
    Hello @Zyxel_Jonas
    I running the GS1920-24HP v2 in standalone mode, however expecting to have the possibility of exchanging the self-signed certificate independent of the mode (never tried the cloud mode yet).
    Q3 sounds good to me. Will wait then.
Nebula Tips & Tricks
