Replace self-signed certificate on GS1920-24HPv2
Hi @alehzn,
For the current designed, NCC doesn't support self-signed certificate feature.
We already understand your request and will move your post to the ideas section so others that have the same need can support this request ?.
Thanks.
Jonas,0 -
Hello @Nebula_Jonas
Thanks for your reply. Do you have a roadmap for this feature? The support for exchanging self-signed certificate is crucial. If it won't be supported in the near future, I have toreturn the switch and look for alternatives.
Thanks for your understanding.
Other question: Do other ZyXEL switches support it?
Hi @alehzn
Yes, we do support self-signed certificate on other Zyxel switch models, as follows:
(for standalone mode only)
XGS4600 and XS3800 on firmware v4.60.
GS1920 and GS1350 (future release around Q3)
I would like to clarify that you would like this feature on Cloud mode? If yes, is it convenient to share your application? Because on cloud mode, all configuration could be done on NCC, it's not necessary accessing to WEB GUI.
-Jonas
Jonas,0 -
Hello @Zyxel_Jonas
I running the GS1920-24HP v2 in standalone mode, however expecting to have the possibility of exchanging the self-signed certificate independent of the mode (never tried the cloud mode yet).
Q3 sounds good to me. Will wait then.
- 588 USG FLEX H Series
- 477 News and Release
