USG 40 - SSL VPN - disable multiple connection for user
we're using SSL VPN to connect to a USG40.
Some users forget to click on disconnect after using the VPN and so, until the reauthentication Time is reached, sometimes it happens that a user connects again and the SSL VPN tunnels get all occupied soon with same users connected multiple times. Is it possible to prevent this?
Thank you
Kari
For each user you can set lease time to 2 minutes and in User/Group > settings you can check Enable user idle detection
The reduced lease time will renew if the user stays connected.
How the USG conduct the idle detection, by scanning packets which are going through the tunnel? But a few packets will be transmitted through the SSL VPN tunnel also always without any user action.
We are using a lot of SSL VPN tunnels, and when established, using RDP sessions to our office computers. Will this be detected by the USG as "not idle"?
Oddly that "Reach maximum number per account" setting is not in USG40
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
