[NEBULA] Tunnel Up Time in Nebula Vpn Hub-And-Spoke
Nertibus
Nertibus Posts: 2
edited April 2021 in Nebula
hi,
i have a nebula vpn network in hub-and-spoke configuration.
what is the max time of tunnel up time?
I have constant disconnections.
does anyone have the same problem?
  • Nertibus
    Nertibus Posts: 2
    I don't think my tunnels can stay up for 86400 sec.
    I believe they fall before the set time
  • Zyxel_Chris
    Zyxel_Chris Posts: 608
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers 500 Comments
    Hello @Nertibus
    How long does the tunnel keep and can you find any error message in VPN category log?
    Is there any service impact you have encountered?
    It might the root cause if your WAN IP is dynamic, since the tunnel need rebuild.
    Chris
Nebula Tips & Tricks
