problemi con zyxel gs1900
alessandro_campi
alessandro_campi Posts: 6 image  Freshman Member
edited August 2022 in Switch
buongiorno
ho problemi di stabilità di alcuni zyxel gs1900 ,perdono l'indirizzo statico che assegno e tornano in dhcp ?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Alessandro_Campi
    Welcome to Zyxel Community
    The forum support for English, please post in English so that other people who is interested in the same topic will be able to join the discussion.
  • alessandro_campi
    Good morning
    I have problems with the stability of the zyxel gs1900, they lose the static protection that I assign and they return to dhcp
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited March 2020
    Welcome to Zyxel community!
    In factory-default setting, GS1900 will get DHCP as management IP when DHCP server is available in the network.
    After you set a static management IP for it, you must click "save" button on the top right to write the config into memory so that it would not go back to DHCP after rebooting.
    Zyxel_Lucious
  • alessandro_campi
    good morning, thank you for your reply
    Everything he communicated to me has been done several times, but the problem has arisen several times.
    I was wondering if it was necessary to update the fw.
  • Zyxel_Lucious
    It's always better to keep your firmware updated, the latest one is 2.50 for GS1900 series.
    The basic idea is the same that remember to click save after configuration change.
    Zyxel_Lucious
  • alessandro_campi
    thanks for the tips
