[NEBULA] NSG50: L2TP VPN connections
KoenP
KoenP Posts: 4
edited April 2021 in Nebula
Hello
Can anybody give me advice, I have a NSG50 configured with L2TP VPN protocol.
This works fine for 1 connection.
When a second person try to connect (with own VPN account) they receive the message, communication disconnected.
Any idea where I can define the number of L2TP VPN connections at the same time?
Thansk a lot formal your advice
  • KoenP
    KoenP Posts: 4
    Thank you "Ivers" for your feedback, indeed this solved my problem..
    Thanks and be safe !Koen
Nebula Tips & Tricks
