Changed default mgmt port to 8443 how do I allow
iSpeed
iSpeed Posts: 110
edited April 2021 in Security
I've Changed default mgmt port to 8443 how do I allow access from outside to manage?
  • iSpeed
    iSpeed Posts: 110
    FYI I also factory reset to see if that will fix reboot hang problem
  • jasailafan
    jasailafan Posts: 181
    5 Answers First Comment Friend Collector Fifth Anniversary
    If you change the port from 443 to 8443 in WWW > HTTPS, you should also allow port 8443 in the security policy rule: From WAN to ZyWALL.
Security Highlight
