GS1900-48HP unable to access the GUI
I have reset the switch and attempted to access at 192.168.1.1. No response from ping. I don't see any devices in the arp list, even checked my DHCP server to see if it picked up an address... nothing.
Unfortunately my model doesn't have a console port or I would be able to see what is really going on.
I guess I have to send this brick back to the stock pile it came from?
Hi @NetKamm
Welcome to Zyxel community!
In order to factory-reset GS1900 series, you have to press the reset button on front panel for over 7 seconds.
Then we would suggest using ZON utility to figure out the switch's IP address, just connect with your PC to scan the switch.
https://www.zyxel.com/form/zon_utility_download.shtml
Zyxel_Lucious
I did hold the reset button down for extended period of time (until the lights flashed) and I did that numerous times. I searched for an hour trying to locate the utility on your website but it was NO WHERE to be found. I never could connect to the default IP nor did I see it grab a DHCP address... I gave and I have returned switch.
Hi @NetKamm
In the provided link above, you'll get an email with download link after the contact info is given.
Kindly have a try if you want.
Zyxel_Lucious
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
