Policy Rule Egress LAGG
Kevin_MTC_Comm
We currently have a few Policy Rules setup for traffic egress on port 24 of our XS3700 as seen below.
policy APolicy classifier AClass egress-port 24 priority 4 dscp 0 tos 0 bandwidth 500000 out-of-profile-dscp 0 priority-action prio-set metering out-of-profile-action drop
policy Management classifier Management egress-port 24 priority 6 dscp 0 tos 0 bandwidth 0 out-of-profile-dscp 0 queue-action prio-queue priority-action prio-set
We are moving the egress to two ports Link Aggregated together, T1 ports 21-22. I thought I could change the egress-port to T1, but that failed in the GUI. I also tried 21-22, but the field is limited to 4 characters. How should these polices be set for a LAGG interface?
Hi @Kevin_MTC_Comm
Welcome to Zyxel community.
For starters, the input of Egress Port will only take effect when "Send the packet to the egress port" is enabled.
But it seems to be not configured in your config.
Is what you want to send the ingress traffic to egress port? If so, make sure you check it.
As for LAG input in Egress Port, please enter the lowest number of the LAG member ports.
In your example, T1 including port 21 & 22, so 21 should be put in.
Zyxel_Lucious5
You have been very helpful. We have additional policies we will review and apply your suggested configuration. Thank you for your response.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
