GS1910-48: How to make a VLAN Trunk? (Firmware V2.00(AAAZ.0)C0)
Zyxel_Lucious said:What is your PC's IP, 192.168.100.10?
If so, management IP of the switch should be in the same subnet, 192.168.100.x/24, but not 192.168.1.2/24.
Zyxel_Lucious0 -
@Webix
Webix said:That worked out perfectly.
However, when i configure the switch ip address with the vlan, i loose access to it. Even if i am on the same vlan.
Example:
- Port 1 is configured with vlan 10, my PC is connected on Port 2 (vlan 1).
- I go to the switch management - ip, and configure the ip has 192.168.100.6 and vlan 10.
- I connect my PC to Port 1 and change my PC ip to 192.168.100.10 (same range of the switch).
And i can't connect to the switch. Not even on vlan 1 i can.
I can get access again if i connect with a usb-com cable to the com port and change the vlan again to 1 on telnet.
Any clue on why is this happen?
Regards
Your PC 192.168.100.10 CANNOT reach 192.168.1.2 due to different subnet.
Just change the management IP to 192.168.100.6.
may be I can just hang on these threat, so I don´t have to make a new one.
I got the same switch with the same software. But I can´t find the trunk funktion. Does this switch support trunks?0 -
Eddwood said:may be I can just hang on these threat, so I don´t have to make a new one.
I got the same switch with the same software. But I can´t find the trunk funktion. Does this switch support trunks?Yes it does support trunks.Here's how i did it:The ports 49-52 are trunks.
Thanks Webix. So that seems pretty simple. I thougt, trunks are doing something spezial as well. So its just like all possible vlans are allowed.:)) IT is sometimes just simple.0
Eddwood said:Thanks Webix. So that seems pretty simple. I thougt, trunks are doing something spezial as well. So its just like all possible vlans are allowed.:)) IT is sometimes just simple.Hello. Yes. You can also, instead of "1-4095", put "10-25,37,39,45-100". It works too if you want to be more selective.0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
