Does NSG100 could replace LiveboxPRO 4 fibre orange French FAI
Antoine_OIS
We have to remove some Livepro4 fibre orange french FAI by NSG100. We know that the internet authentication use PPPoE on vlan 835 without QoS, but when we try to connect we don't have any Ip.
Is there anyone who succeeded to configure it?
Thanx for the help,Antoine
Hello @Antoine_OISWelcome to the Nebula forum.
I'll PM you for detail info. on this case, please check your inbox message.
hi @Antoine_OIS
Welcome to the forum
There is a lof of information about how to replace livebox at
https://lafibre.info/remplacer-livebox/
I hope it helps.
Regards
Thx alfonso for your answer, but apparently it's not possible with NSG device. So we tried to do this with ER-X Ubiquiti and the NSG...Regards
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
