How do I revert the firmware back to 6.00?
JamesRonald
I updated my NWA1123-AC PROs to 6.10 which seems to be causing problems how do I revert the firmware back to 6.00? I'm using nebula.
Hi @JamesRonald ,
May I know what's the problem you have after upgrading to the v6.10?
Would you share the issue symptom for us?0 -
All.. I am having problems too with one of my AP which is also a NWA1123-AC.. it is performance is awful since upgrading to latest firmware ... I have to reboot it every morning and mid afternoon.. and throughput is slow0
Hi @MikeB ,
We got the site information from @Nebula_Bayardo and the issue behavior. We'll check it and update for you as soon as possible.0 -
Hi @MikeB
I collected the logs from your site and found the channel utilization of 2.4G is high. It seems the current channel is not good enough to use. As you mentioned the performance will be better after rebooting, I thought this might be because the DCS works to scan a better channel to use at that time. Would you like to try to use DCS when you feel the performance does not work as expected?
Please disable the DCS client aware. Otherwise, it might not change the channel if there is still a station connecting to it.
Thanks.
Joslyn0 -
Hi @JamesRonald @MikeB
We have released 6.10 p3 which fixed the 2.4g connection issue. Would you like to upgrade the firmware and observe if it is getting better? Please go to Nebula and upgrade the firmware directly.
Joslyn
- 588 USG FLEX H Series
- 476 News and Release
