XGS1930-52HP 10G port cannot link up
I've bought 2 XGS1930-52HP, while connecting both switches with dac cable on port 49~52, it won't link up. I'm pretty sure that the dac cable is in good condition, because I've tested it on other device. Is there anyone here also encountering the same problem? Thanks in advance.
D,
D,
Hi @D_Shadow,
You will need to access the local web GUI of the switch and change the port media type to "dac10g" mode to be able to link up using dac cable, as figure below:
WEB GUI > Basic Settings > Port Setup
Hope it helps.
Jonas,Jonas,0
Hi @D_Shadow,
Hope it helps.
Jonas,Jonas,0 -
Hi Jonas,
At last, the link is up now.
Thanks for the answer.
Just wondering, why it cannot be configure on Nebula?
D,0 -
Hi @D_Shadow,
Thanks for the suggestion.
I would like inform that, it was already included on our roadmap.
Please stay tuned.
Jonas,0
- 588 USG FLEX H Series
- 476 News and Release
