Sometimes no VPN connectin possible
sometimes if i make a vpn l2tp connection with my usg 1000 , the client connects , but after logout en trying to login again it fails , this happens every time after a succesful login.
after 3-4 attemps it seems not possible to login again on the same internet connection, if i switch to another internet connection i can make the connection ! the client is a windows 10 pc , can this be fixed ? , is this a client problem or a zywall problem ?
yes the Dead Peer Detection is enabled , problem is all clients are windows 10
i also tried to reset the network settings, but not works
ipconfig /flushdns (Clear the dns cache)
netsh int ip reset (reset ip settings)
netsh winsock reset (Reset Winsock Catalog)
Which firmware version you use for?
As I know seems already fixed many L2TP issue before..0 -
3.00(AQV.3) / 1.15 / 2012-06-05 09:47:11
i found this firmware for the usg 1000 , 330AQV8ITS-WK41-r74145
( is this the good one ? )
is it simple to upgrade the firmware i can not found a guide
Hello kriszty,
I suggest to upgrade your device’s FW to the latest one firstly, this issue should had been fixed on this FW version.
The download link will be PM to you.
Charlie
i just upgraded the zywall with the newer firmware, but still having problems with getting a vpn connection. in the log file i see it tries to login, but it gives an cookie pair error. on other pc,s i can login with vpn, but on 1 pc it always gives this fault
is there also an external vpn l2tp app available for download anywhere ? , maybe this can be better
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
