Error creating a RADIUS SERVER connection
Infotecnika
Hi!,
I,m trying to configura an external radous conecction in NCC. Wathever i put on the connection fields, im getting an error when i,m tring to save the configuration saying:
INVALID_VOICE_VLAN_PRIORITY.
Im trying to create a RADIUS POLICY per mac authentication but the same error. I have not badwith management defined etc so i don,t know why im getting the error and cant save the changes into NCC-SWITCHES-RADIUS config.
Its a bug or aim doing something bad?
Attaching screen of error (captured password its not real one)
Hi @Infotecnika,
Regarding this case, your site has already been hot fixed.
This issue is related to our backend which there is a chance to be triggered if the site was created before phase 9.2. The issue is already fixing in progress and will be fixed soon.
Sorry for the inconvenience.
Jonas,Jonas,5
Hi @Infotecnika,
Thanks for the screenshot.
Please provide your org/site name to us and enable Zyxel support located at HELP > Support request, so I could check the current status.
Thanks,
JonasJonas,0 -
Hi i,ve enabled access support as you asked us.->Sitename: CMU Mr0
Infotecnika said:Hi i,ve enabled access support as you asked us.->Sitename: CMU MrSorry, my previus message was truncatedOrganization: CMU Marque... (I truncate de full name due to protection data)Site: Madrid0
Ok.Thank you very much.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
