Auvik - Integration
NetworkTotalIT
NetworkTotalIT Posts: 6 image  Freshman Member
edited August 2022 in Switch
Hi all,
We've recently switched to Auvik monitoring, it seems our Zyxel switches aren't providing data to this platform, is this beyond the current capability of Zyxel switches?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited July 2020
    Hi @NetworkTotalIT
    Welcome to Zyxel community.
    I assume that "Auvik" is also using SNMP for monitoring, correct?
    What model of Zyxel switch do you currently use?
    Zyxel_Lucious
  • NetworkTotalIT
    Hey,
    sorry Zyxel_Lucious didnt see the reply.
    Its the GS2210-48HP.
    And yes Auvik is an SNMP monitoring platform that can also utilise CLI to manage the switches configurations.
  • Zyxel_Albert
    Zyxel_Albert Posts: 36 image  Zyxel Employee
    First Answer First Comment Friend Collector Third Anniversary
    Hi @NetworkTotalIT,
    GS2210 does support SNMP and CLI. Please make sure your monitor system can reach the switches, you can try to ping the switches to see if they are reachable, and make sure the community is matched. Also you should check the switches if there is ACL or remote management setting block the Auvik system.
    If all of the setup are correct we may need to know which mib(OID) you try to monitor.
    Zyxel_Albert
