USG not comunicate with specified IP address
RaphaelOIiveria
This is my case.
We have a rang of WAN IPs (Ex: 192.168.0.96-255.255.255.248)
If I configure WAN1 or WAN2 or WAN sub-interface with the IP 192.168.0.98 this ip not work, I can't ping internali this IP, but if I configure other IP address range (97,99-101) my USG work well.
Some one has ideia about this?
This is my case.
The mensage bellow is show when a ping the ip .98
ping: sendmsg: Operation not permitted
Hi @RaphaelOliveira,
For some ISP, some IP addresses are used for access link only, not for data link.
When you configure 192.168.0.98 in wan1, use the following command on web console to check the ping result.
Router# ping 8.8.8.8 interface wan1
Before entering the command, capture packets on wan1 interface and filter by icmp.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
