SSID Schedules disappearing days
When I adjust a schedule for an SSID, if I make the SSID unavailable for one of the days (by sliding the two endpoints to the same time) then after I save the changes the whole day disappears from the schedule and I am unable to access that day anymore.
How do I get my days back? How do I avoid this problem?
Hi @fissure
I can see the symptom as you described. If dragging the two endpoint as overlapping, the Day will be disappeared after saving. We are realizing the behavior now.
To get the day back, you can choose the Schedule template and save it. Then go back to the Custom Schedule, the Day should be available.
If you want set the SSID as unavailable for one day, please turn off the button and drag the endpoint to leftest and most right side. It should work
Joslyn0 -
Hi @fissure
We already fixed the issue. After dragging the endpoint to the same time, we will turn off the button directly. It will avoid the day disappear. Please have a look.
Joslyn0 -
thank you!
now i have a feature request: could you make it so we can access/adjust the ssid schedules through the iOS app? that would be very convenient.
thank you for your help0 -
Hi @fissure
Thanks for your opinion. This is a good suggestion for us. I will create a topic in our idea category.
Joslyn0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
