Welcome to Nebula Forum. You can configure Voice VLAN on Switch > Configure > Switch Configuration> Voice VLAN (Turn on). There is a priority dropdown list similar as QoS to allow user prioritize voice packets on specified OUIs manually.User configurable priority is from1(Lowest) to 6(Highest). In order to address your case, we recommend the priority is set to 4 with Voice VLAN ID (eg: VLAN 2). Then configure the uplink port(s) with PVID 2 and access type on SWITCH > Configure > Switch port(s). You can tick multiple uplink port(s) simultaneously with the same PVID and port type setting. By doing so, the priority of voice packet is higher the data from PC. However, just like @ocean77 said it would be a tradeoff and less manageable to share the voice with normal traffic.
