NWA1123-ACv2 Upgrade failed
C0nvert
C0nvert Posts: 3 image  Freshman Member
edited April 2021 in Nebula
I was trying to Update my NWA1123-ACv2 to an newer Version.
Currently i have an old Version on it (Blue UI).
If i'm trying to Upgrade it , it always stays on the same Firmware after a 3 min Timeout and no reboot.
I get no Error Message.
WebUI Upgrade nor FTP Upgrade Method seems to work.
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @C0nvert
    For firmware upgrade, we suggest not to cross too many version. If you are using v4.26, just upgrade it to v5.00 then v5.10 because it will avoid some configuration parse error.
    Can you let me know your original firmware version and will upgrade to firmware version?
    Joslyn
  • C0nvert
    edited November 2020
    It doesn't mather if i use v5 Firmware or newer.
    For a brief Moment i had the new Interface v5.10 but after a router restart it got back to v2
    Thought it could be a Problem with the Browser Cache, so i deleted the Cache from Chrome and tried even a different Browser.
    Same result. Only the old UI v2 is visible.
    Edit i'll try something and will report later
  • Angelyc
    Angelyc Posts: 6 image  Freshman Member
    Hi @C0nvert
    Would you mind to provide firmware upgrade timeout screenshots? Actually I'm curious about the old UI v2 that you mentioned.
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    Did you get resolved? Maybe fully factory reset before trying?
Nebula Tips & Tricks
