Last Heartbeat Time Zone
sebala
sebala Posts: 17
First Comment Nebula Gratitude Third Anniversary
edited April 2021 in Nebula
what is the time zone used for Last Heartbeat in VPN connections screen ? (Under NCC > Security gateway > Monitor > VPN connections)
Sebastien
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 289
    5 Answers First Comment Friend Collector Fourth Anniversary
    Hi @sebala,
    After doing some test, I had successfully duplicated the time zone issue on my side. We are already fixing this problem and will have you update once it's fixed.
    Sorry for the inconvenience.
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi @Sebala,
    The last heartbeat time zone is based on the local time zone configured in the general settings.
    Jonas,
    Jonas,
  • sebala
    sebala Posts: 17
    Something should be wrong.
    In general settings, I've set France
    In NSG VPN connections (for same site), I have this :
    It is currently 2020-12-03 14:28 in France (UTC+1)
    So the Heartbeat is UTC+8 (Hong Kong, Singapore...)
  • Zyxel_Jonas
    Hi @sebala,
    May I know your organization/site name and please activate Zyxel support (located at HELP > Support request). I would like to check the status on your site, because as I've checked it is normal on my side.
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi @sebala,
    I would like to inform that the issue was already fixed.
    If there is any service needed, please feel free to let me know.
    Jonas,
    Jonas,
Nebula Tips & Tricks
