Black listing wildcard issue on NSG50 V1.33 ABHP.4
thwartedEfforts
Among numerous domains in my NSG50 Black list at Security gateway > Configure > Security service I have the following wildcard entry:
The issue is that the wildcard does not seem to be behaving in the expecting manner. If I browse to:
https://yt3.ggpht.com/
then my browser displays a response from the web server in defiance of the above
However, if I update the NSG Black list to the FQDN:
I will correctly receive the Web access is restricted. Please contact the administrator denied access message from the NSG. I can replicate this with all the other domains in my list e.g. *.ytimg.com
It appears the wildcard is not working?
*.ggpht.com
yt3.ggpht.com
Hello @thwartedEffortsI can't reproduce this problem, can you activate the support request and provide your org./site name for me then I can check with your device configuration
Chris
Chris,
I've responded via the Nebula interface using the Ask Question pop-up in the bottom right corner. However, I've just discovered the separate Support request page which allows me to invite Zyxel support as administrator so I'm about to fill that out too.
Not sure if you are able to close the duplicate Ask Question request.
UPDATE case no. #2012002180
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
