UAG5100 Guest login without code
What have I done wrong?
Hi @Eddwood
You can go to Configuration > Object > Address to Add IP object.
After added this object, then you should able to find this object in drop down list of source address.
Hi @Eddwood
If you would like to force client authenticate with UAG before access to internet, you may enable “Web-Authentication” function and setup client source IP address in the rule.
In the default rule, lan2 client required to authenticate with UAG before access to internet.
Of course you can add the rule to exclude IP address range for guest device without authentication required.(you may setup static IP on guest PC)
Hello Stanley, Well, it works that I can´t login without a tickt. But I I can´t login anymore. In your picture ist on "source" the guestpc Range. I have a Vlan in lan1. with a different IP Range than the interface lan1. How can I switch the source from Lan1--subnet?
The divece gets the correct VLan IP Range. in my case: 10.100.1.1/22
The subnet in Lan1 ist: 192.168.0.0/230 -
Hi @Eddwood
Thanks stanley. It works:))0
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
