IDP ADP signature update issue recovery SOP_final
hansjalbertsson
The document in the subject line is confusing in many ways:
The ip-address to connect to in the described procedure varies randomly.
There's a link to download the latest idp license signature, a link that appears dead.
What gives?
What gives?
Which document you referenced? Do you have the link?
"There's a link to download the latest idp license signature, a link that appears dead" You mean the link in the device GUI to let you update your signature or?0 -
Hello hansjalbertsson,
The issue should be solved on latest firmware, so you dont need to do any configuration from this SOP. I would like to know what issue do you face after you upload the latest firmware?
Charlie
The pdf document refers to this link
https://zfs01.zyxel.com.tw/bds/Login.do?id=A03781310&p1=z9j13wjsbeijcecblhdgjh20
where you're supposed to find the latest idp signature but that link is dead.
Now the document in that pdf is a bit confusing, and seems to have been cut&pasted fromseveral different sessions,w/o adjusting the example ip-s and checking if links were temporary or permanent.
So, I believe there's either a newer link, or the gui after fw-update to the latest dec-2016 version will handle a signature update.0 -
Zyxel_Charlie said:Hello hansjalbertsson,
Charlie0 -
hansjalbertsson said:Zyxel_Charlie said:Hello hansjalbertsson,
Charlie
Charlie0 -
Thank you, we have that loaded on both usg-s now0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
