Multiple SSL VPN scenario's
I am wondering if it is possible to have multiple SSL VPN scenario's for people to use with SecuExtender.
Reason for this is, I have a SSL VPN setup nicely to access certain LAN segments however I need another person to also SSL VPN in to teh LAN but to other LAN segments.
Is this possible and if so, how?
Jeroen
Jeroen
With SSL VPN you can add another with different user and IP pool then select the a network needs to access.
- 588 USG FLEX H Series
- 477 News and Release
