ZyWall USG2000 FW 3.30(AQW.7)C0 gets "Unable to connect ZySH daemon", WebGUI won't work
hansjalbertsson
Posts: 34 Freshman Member
ZyWall USG2000 FW 3.30(AQW.7)C0 gets "Unable to connect ZySH daemon" when in ssh as admin, WebGUI won't work.
What do I do to get it working, and what could be the reason??
Dear @hansjalbertsson
I would suggest you flash the usg with the latest Weekly firmware available:
ftp://cpeguest02:cpe2005@ftp.zyxel.de/USG_3.00_weekly_date_code/V330_based_2016/2016-WK48/USG2000/330AQW7ITS-WK48-r74988.zip
Basicly FTP upgrade would be advisable.
So connect a pc in your local lan wired to the usg
start a command prompt with admin rights
then type ftp [zywalls ip address] and login with admin and password
Then if successful , set the mode to BINIARY with the command : bin
after that give the command put c:\firmware.bin [location where firmware is downloaded]
Hit enter and it will start the firmware upgrade..
Let me now if you have any questions !
Kind regards
Mark
5
Kind regards
Mark
5 -
Is it all the time showing "Unable to connect ZySH daemon" or just in short period? If it just showed in short period, could be the system just busy on handling something else for minutes.0
Mark said:Dear @hansjalbertsson
Kind regards
Mark
It's a permanent state.
Kind regards
Mark
ftp> put 330AQW7ITS-WK48-r74988.bin /Firmware
because I think the usg looks for the bootable FW in /Firmware, doesn't it?
Ftp from windows doesn't work!!!??? Any ftp from any of my Unix machines seems to work OK.
No this is not needed If above does not work for you it seems more alike a local issue on your pc.. (firewall, anti virus,software) what is causing an error... you can also use on your windows client a software tool like FILEZilla.. there you just connect again with the usg en drag en drop the bin file directly in the root .. This is also applicable to almost all our modern firewalls, Acces points, wireless controllers and home routers/modems
Why is then the old firmware in there named /Firmware??
Re ftp not working: FileZilla works very well.
PROBABLY I have some issue with my W10 firewalls, I am NOT a Windows person.
i guess you are pointing to the standby firmware? but then again i am 100 % sure what is said.. I do like daily upgrading cases with ftp. you can also check our one security site:
http://onesecurity.zyxel.com/tutorials
then under [Firmware Upgrade Procedure] you can find a document where you can see the same
And this is true even in a USG2000 ???
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
