Specify IP
Hi @classYou can go to Configuration > Network > IP/MAC Binding to bind E-mail server mac address with a static IP (just as the following example) and release, renew E-mail server IP address. Finally, check your IP address If been changed and test it again.
It can use virtual interface IP?Zyxel_Jeff said:Hi @classYou can go to Configuration > Network > IP/MAC Binding to bind E-mail server mac address with a static IP (just as the following example) and release, renew E-mail server IP address. Finally, check your IP address If been changed and test it again.
Hi @class
Would you mind checking your VM server interface setting? We suggest that it set to bridge mode(such as following virtual-box setting).
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
