ZyWall USG 100 - wrong fs type at boot
Hi all,
i've a Zywall USG 100 with the following issue...
Suddenly it stops to work...
Connected via serial cable, tryed to restore firmware...config...restore image...i succeed to transfer but when it try to apply get always the same mount error.
This is its actual state:
FLASH: AMD 16M
BootModule Version: V1.13 | 12/10/2010 05:20:17
DRAM: Size = 256 Mbytes
Kernel Version: V2.4.27 | 2015-01-08 20:37:07
ZLD Version: V3.30(AQQ.7) | 2015-01-13 16:30:24
Press any key to enter debug mode within 1 seconds.
Start to check file system...
/dev/hda2: 13/18216 files (0.0% non-contiguous), 9327/72704 blocks
/dev/hda3: 42/43648 files (0.0% non-contiguous), 11206/174080 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 180 seconds..With SYS led always flashing.
Any help/suggestion?
Thanks in advance!
Thanks in advance!
Strange, did you power off the device during uploading fw or the fw you downloaded is incomplete? Maybe you can try to recover the firmware, the SOP was mentioned in the release note page 61.0
Yes...i've recovered but it fails to boot.
Now i'm seeing this during boot:FLASH: AMD 16M
CF read: device 0 not ready
IDENT command error: 0xf0
ERROR
Kernel Version:
ZLD Version:
ERROR
Enter Debug Mode
USG 100>
This after uploading firmware:
USG 100> atkz -f -l 192.168.1.1 -f -l 192.168.1.1 OK USG 100> atgo Booting... Connect a computer to port 1 and FTP to 192.168.1.1 to upload the new file. Firmware received ... FLASH: AMD 16M BootModule Version: V1.13 | 12/10/2010 05:20:17 DRAM: Size = 256 Mbytes Kernel Version: V2.4.27 | 2015-01-08 20:37:07 ZLD Version: V3.30(AQQ.7) | 2015-01-13 16:30:24 Press any key to enter debug mode within 1 seconds. ..................... Start to check file system... /dev/hda2: 13/18216 files (0.0% non-contiguous), 9327/72704 blocks /dev/hda3: 39/43648 files (0.0% non-contiguous), 11098/174080 blocks Done mount: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or other error In some cases useful info is found in syslog - try dmesg | tail or so Kernel panic - not syncing: Attempted to kill init! Rebooting in 180 seconds..
Sometimes:
USG 100> atgo Booting... Connect a computer to port 1 and FTP to 192.168.1.1 to upload the new file. Firmware received ... Start to check file system... /dev/hda2: 11/18216 files (0.0% non-contiguous), 6433/72704 blocks /dev/hda3: 11/43648 files (0.0% non-contiguous), 9640/174080 blocks Done Building ... [Update Filesystem] Updating Code \ FLASH: AMD 16M BootModule Version: V1.13 | 12/10/2010 05:20:17 DRAM: Size = 256 Mbytes Kernel Version: V2.4.27 | 2015-01-08 20:37:07 ZLD Version: V3.30(AQQ.7) | 2015-01-13 16:30:24 Press any key to enter debug mode within 1 seconds. ..................... Start to check file system... /dev/hda2: 12/18216 files (0.0% non-contiguous), 23910/72704 blocks /dev/hda3: 22/43648 files (0.0% non-contiguous), 9651/174080 blocks Done mount: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or other error In some cases useful info is found in syslog - try dmesg | tail or so Kernel panic - not syncing: Attempted to kill init! Rebooting in 180 seconds..I think the eeprom or similiar is out...
Something like this....
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=010780&lang=EN
Hello Logic,
in order to provide you with a better assistance, I will contact you through private message to proceed with RMA process.
Charlie0
- 441 Beta Program
- 293 Service & License
