VPN Configuration
terryw
terryw Posts: 5  Freshman Member
edited October 2017 in Smart Home Product
Hi Has anyone set up VPN on the Zyxel VMG8924-B10A, unfortunately the manual is woeful in this area. A detailed explanation of the VPN setup page would be very helpful. Thanks
#CPE_October
  • Johan
    Johan Posts: 27  Freshman Member
    Then what you want to set up is a client to site VPN-tunnel.
    I do not believe it is possible to set up a client to site VPN on a VMG8924-B10A, only site to site. So for you I believe the way to go would be setting up a client to site VPN-server on a computer behind the router. This computer would of course need to be powered on when you want to use it. You would also need to port-forward/NAT the ports required for VPN to your PC.
