VMG1312-B10D PROPER Factory Reset
duggyfresh
Hi.
I have a second-hand VMG1312-B10D that I would like to use with a digital mixer and a PC. I have performed a factory reset that seems to have completed successfully.
The default router login password after a factory reset (1234) is not recognised and I believe that the ISP that originally supplied the router to the previous owner may have loaded a custom firmware that included an unknown (to me) password.
Is it possible to restore the firmware to the original factory default (admin,1234) without having access to the web/telnet interface of the router, e.g. USB key or some such? If not, what options do I have to gain access to it?
Regards and thanks in advance for any information.
Duggy.
#CPE_October
Duggy.
#CPE_October
if the isp changed the password, maybe you need to check with the owner.
It looks like that there is a customized firmware inside that device0 -
Thanks for the reply. I agree about the custom firmware.
Unfortunately, I bought it from a charity store and they don't have a record of the original owner. Hence my question about how to install a new firmware without access to the web interface.
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
