Help with NAS326
kcbass1
Hi All, I'm using a NAS326 as a movie/music server. What it does to some of my movies is change the file name to "EVO". Does anyone have this same problem and did you do about it. If I access the file from my pc they are correctly named but from my Samsung tv, EVO.
#NAS_October
#NAS_October
I have not heard of anything like it before. Are you sure it is not your TV that does it? Considering EVO is in its name?
Hi Johan. Thanks for your reply. The reason I don't think it's the television is when I plug in the old USB hard drive that most of the "EVO" movies came from it doesn't do it. The file names stay proper.
P.S. The tv name isn't named EVO, the movies on the NAS326 names get changed to EVO. Example, A movie tittled "Superman" would show up named "EVO". And according to wikipedia... Enhanced Video Object, also known as Enhanced VOB or EVO, is a container format for HD DVD video media. It contains the actual digital video, digital audio, subtitle and DVD menu contents in stream form. It is an extension to VOB. It can contain video encoded in H.264/MPEG-4 AVC, VC-1, or H.262/MPEG-2 Part 2 and audio encoded in AC-3, E-AC-3, Dolby TrueHD, DTS, DTS-HD, PCM, and MPEG-2 Part 3.There are a few consumer software solutions that can play EVO files, such as PowerDVD, WinDVD for Windows and FFmpeg for Linux (unprotected EVO only), and the cross platform VLC Player.
Anybody!?!0
Why don't you try using another application to watch movies on your Samsung TV0
Thanks to this topic of you, I am using a Samsung smart TV, I found the problem for the problem I am having.
Install oreo-tv.net entertainment application providing free movies, TV, music at the website: https://oreo-tv.net/
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
