Signature Windows Update
Hello AKSYS,
As your description,
I would like to confirm that do you want to limit the speed of Windows update?
If yes, please follow the steps as following.
Create the application profile which is Windows_update on application page.
Go to Application>Add>Select Security update tools and press search>tick Microsoft Windows update
Go to BWM>ADD>Select Application Object and also choose "Wupdate" profile>Limit inbound and outbound of the speed of windows update under 500kbps
Enable BWM feature, and press apply.
Charlie
This method does not work because we have an USG without licences UTM (Zyxel support)
Have-you got an idea to create a signature ?
Hello AKSYS,
For this method,
the IDP/AppPatrol license is required, so if you dont have license on USG, the solution does not work.
Charlie
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
