NSA325 Firmware upgade problem
djep
djep Posts: 2  Freshman Member
edited November 2017 in Personal Cloud Storage
After I did a firmware upgrade to the latest version: 4.81, my Zyxel not working anymore.
The first led continuously flashing in green, and I can't access the share, or web interface.
I tried with reset button, turn off power and on again, but nothing happens. It's not first firmware upgrade, but with this I have trouble. What can I do?
It is a manual procedure to install the firmware from USB stick? Can anybody help me with instructions. Thank you in advance.
#NAS_October
  • djep
    Thank you very muc@Fredzoul1, I succeeded with above method, after three attempts. Front USB port (USB 3) didn't work. But the rear USB port worked like a charm. Thank you again.
  • Fredzoul1
    Fredzoul1 Posts: 97  Ally Member
    Perfect :-) I'm Happy
  • mikew
    mikew Posts: 1  Freshman Member
    I've got the same problem, during an upgrade, it got stuck with flashing orange light and no more........
    When I try to follow the link it fails.
  • Batou
    Batou Posts: 101  Ally Member
    edited August 2018
    Through this article, it seems the server is not ready yet, because the data center was just moved.
    https://homeforum.zyxel.com/discussion/comment/2881#Comment_2881/
