Can I sync two NAS540's over the internet?
nwmike
I want to mirror my main NAS540 to another one at a different location. Can this be done so that is syncs changes dynamically?
Hi @nwmike
With the scheduled backup and rsync option, you can make backup with a distant NAS. You have option to choose external location and use IP (perfect only with a fix IP) or using dynamic domain name. You have to open port on the way in the distant router for accessibility (default port for rsync is 873).
Here screenshot, but sorry it's in french... After the 3rd screenshot you have to continue the procedure with choice of the folder destination, date, hours, ... :-)
Hope this help you !!!
Hi @nwmike
Thank you for this! I will look into setting this up, Merci!
Is there any way to do over CLI?
This aplication only allows to rsyc FROM the Zyxel and not TO the Zyxel.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
